  CATIA V5 Programmierung
  FTA Capture / View / Camera renaming
KISTERS 3DViewStation WebViewer-Integration für Mendix verfügbar, eine Pressemitteilung
Autor Thema:  FTA Capture / View / Camera renaming (1222 / mal gelesen)
Sylas
Sehen Sie sich das Profil von Sylas an!   Senden Sie eine Private Message an Sylas  Schreiben Sie einen Gästebucheintrag für Sylas
Dell Precision T3500
Intel Xeon W3550 @ 3,07 GHz
12 GB RAM
CATIA V5 R28
erstellt am: 27. Jun. 2024 11:43    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hello Community!
I'm trying to write a code to automatically rename captures / views / cameras.
The problem occures when there's more then one capture based on (supported by) the same view. What I want in this case is to preserve viewm name from the first rename occurance. Instead of that - my code renames it each time  I tried to use ActiveViewState property, but it seems not working. Below my code - maybe someone could give me some tips...
Code:
Sub CATMain()
'On Error Resume Next
Dim oAnnSet As AnnotationSet
Dim odSel As Selection
Dim oSel
Dim InputObjectType(1) As Variant
Dim oTable() As Variant
Dim oPart As Part
Dim oDoc As Document
Set odSel = CATIA.ActiveDocument.Selection
Set oSel = odSel
InputObjectType(0) = "Product"
InputObjectType(1) = "Part"
Result = oSel.SelectElement2(InputObjectType, "Choose FTA", True)
If TypeName(oSel.Item(1).Value) = "Product" Then
    Set oPart = oSel.Item(1).Value.ReferenceProduct.Parent.Part
    Set oDoc = oSel.Item(1).Value.ReferenceProduct.Parent
Else
    Set oDoc = oSel.Item(1).Value.Parent
End If
Dim oAnnotationSets As AnnotationSets
Set oAnnotationSets = oPart.AnnotationSets
Set oAnnSet = oAnnotationSets.Item(1)
Dim oCapture As Capture
Dim oCamera As Camera3D
Dim oActiveView As TPSView
Dim oNameTable() As Variant
ReDim oNameTable(oAnnSet.Captures.Count - 1)
'captures naming pass 1
For i = oAnnSet.Captures.Count To 1 Step -1
    Set oCapture = oAnnSet.Captures.Item(i)
    If Left(oCapture.Name, 2) <> "C." Then
        oCapture.Name = "C." & oCapture.Name
    End If
Next
'captures naming pass 2
    If Left(oCapture.Name, 3) = "C. " Then
        oCapture.Name = Replace(oCapture.Name, "C. ", "C.", , 1)
    End If
Next
'captures naming pass 3
    If InStr(1, oCapture.Name, "/") <> 0 Then
        If InStr(1, Mid(oCapture.Name, InStr(1, oCapture.Name, "/") - 1, 3), " ") = 0 Then
                oCapture.Name = Replace(oCapture.Name, "/", " / ", , 1)
        End If
    End If
Next
'cameras and views renaming
'Set oActiveView = Nothing
'For i = oAnnSet.Captures.Count To 1 Step -1
For i = 1 To oAnnSet.Captures.Count
    Set oCamera = oCapture.Camera
    'cameras naming
    If InStr(1, oCapture.Name, " / ") <> 0 Then
        oCamera.Name = Mid(oCapture.Name, 3, InStr(1, oCapture.Name, " / ") - 3)
    ElseIf InStr(1, oCapture.Name, "/") <> 0 Then
        oCamera.Name = Mid(oCapture.Name, 3, InStr(1, oCapture.Name, "/") - 3)
    Else
        oCamera.Name = Mid(oCapture.Name, 3)
    End If
    If oCapture.ActiveViewState = True Then        '<------ this should work for captures without supporting view, but it's not :(
        Set oActiveView = oCapture.ActiveView
        oActiveView.Name = Mid(oCapture.Name, 3, Len(oCapture.Name))
    End If
    oNameTable(i - 1) = oCamera.Name
Next
oSel.Clear
'deleting unused cameras
For j = oDoc.Cameras.Count To 1 Step -1
    If IsInArray(oDoc.Cameras.Item(j).Name, oNameTable) = False Then
            oDoc.Cameras.Remove j
    End If
Next
MsgBox ("Done!")
End Sub
